Laminate Trimmer Questions + Routing Truss Channel http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=20433 |
Author: | archtop [ Sat Jan 10, 2009 12:39 pm ] |
Post subject: | Laminate Trimmer Questions + Routing Truss Channel |
As I said in one of my recent posts, I'm much more of a "hand tool guy" than a "power tool guy". I guess I fall into that "Neanderthal" category. Can't get enough hand tools, old or new. A few days ago I received my first-ever laminate trimmer. It's a Bosch Colt. I was delighted to see the glowing remarks about this particular trimmer here. I bought it basically for it's specs and because I was on a tight budget. After the drill press and bandsaw, this will be my third power tool. ![]() So here are my questions.... First off, I barely see any info regarding the laminate trimmer being used for certain procedures. It's always a router being used. Now I know there's a difference, but in some cases can I just use those articles or tutorials that include the router and just replace "router" with "laminate trimmer"? Or would that not work? Point is I don't see a lot of articles or tutorials where the lam trimmer is used, but a lot where the router is. Second question.... Can I use this trimmer to rout the truss rod channel in my neck when the time comes? I know there will probably be a lot of jigs involved but I just wanted to get an idea what else I can do with this thing. To be totally honest about it I only bought it to go along with the Stew Mac TrueChannel Routing Jig and I needed something that wouldn't break the bank. Everything else I planned doing all by hand. But now, after reading what a great tool it is I think I might be catching the power tool bug!! ![]() -John |
Author: | Alain Moisan [ Sat Jan 10, 2009 1:09 pm ] |
Post subject: | Re: Laminate Trimmer Questions + Routing Truss Channel |
You can view your laminate trimmer as a lower powered, lighter router. So yes, you can do anything a router does with a laminate trimmer, unless it's not powerfull enough. Many , if not most builders essentially use laminate trimmers and not routers. With it you can (amongst otehr things): - route binding chanels - route your trussrod chanel - shape your peghead (using a template) - route your neck joint - and so on, and so on... All this to say that you should not have any problems finding good use with your new toy! |
Author: | archtop [ Sat Jan 10, 2009 2:16 pm ] |
Alain, thanks! I wasn't quite sure about the scope of this tool, but I'm learning. And I'm certainly glad it can do most things routers are capable of. Both tools seem to offer a lot of versatility! -John |
Author: | Mark Groza [ Sat Jan 10, 2009 2:44 pm ] |
I have large routers, but don't use them for guitar building.All i use for building guitars is a colt and many dremel tools and other laminate routers.I just feel the large routers are too big for my guitar building needs.Just don't take too big of a bite at a time, which shouldn't be done with large ones either and you will be fine. ![]() |
Author: | Heath Blair [ Sat Jan 10, 2009 8:44 pm ] |
did your new colt come with an edge guide? mine did and it will definitely help in routing the truss rod channel. the only thing i would say is to add a longer fence to the guide. otherwise, it might be a bit short to get a straight cut at the heel end of the neck. the guide starts to tip because of lack of contact with the side of the neck shaft. |
